How to determine exact MCS7800 model?
Answered Question
Sep 12th, 2007
How can I determine the exact model of an MCS 7800 series server? From the outside their is not reference to specific model (cover plate only stated MCS7800). Inside the box I have determiend it's a DL320. But haven't been able to determine specific model.
thanks
Correct Answer by Chris Deren about 9 years 10 months ago
If the server is CM 4.X or prior you can look in registry under:
SOFTWARE\Cisco Systems\System Info\Hardware key
Chris
Overall Rating: 5 (1 ratings)
mchandak Wed, 09/12/2007 - 05:51
  • Gold, 750 points or more
A DL320 is equivalent to a MCS-7825. Normally you should have got a sticker on the lid of box which would say the exact model of the box. Also, the newer generations of MCS7825H had a label on the left of the HDD which can be pulled and contains complete information about the exact server model
Correct Answer
Chris Deren Wed, 09/12/2007 - 06:01
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
