Transfer to voicemail when you dial DID
Sep 12th, 2007
Why, when I call a DID number does it not go to the relevant voicemail on no answer?
This happens when I configure the DID number as a secondary number for an extension, and when I configure a dialplan-pattern, eg:
dialplan-pattern 1 44751. extension-length 3 extension-pattern 20.
Avner Izhar Thu, 09/13/2007 - 22:57
What voicemail is it? CUE? I'm guessing you are using CME, what version of IOS?
Regards, Avner.
davieshuw Fri, 09/14/2007 - 01:17
Right I can see whats happening. When I have my dialplan-pattern on, my extension number isnt being presented to CUE properly. When I take it off, it works fine.
My set up is like thus:
my extension is 512 for example. My ddi number is 02920117512
My voicemail is 600
I have:
dialplan-pattern 1 117... extension-length 3 extension-pattern ...
Hmm. So my dialplan is stopping my extension number getting to CUE. Any ideas?
Avner Izhar Fri, 09/14/2007 - 07:32
It is a well known behavior of the dialplan-pattern, as documented in cisco bug CSCee57422.
Use voice translation rules instead of the dialplan-pattern and you should be fine.
HTH, Avner.
davieshuw Fri, 09/14/2007 - 07:45
Well i've implimented the following to make that work:
voice translation-rule 3
rule 1 /^.*\(...\)/ /\1/
voice translation-profile profile1
translate calling 3
dial-peer voice 2000 voip (CUE dial peer)
translation-profile outgoing profile1
And I can have DDI's and call my voicemail from my extension. However, now my ability to leave internal - internal voicemail has gone!!
Avner Izhar Fri, 09/14/2007 - 11:04
I'd recommend going to the path where you use the translation inbound and outbound of the pstn and not undo the dialplan-pattern towards the cue.
Create a voice translation rule which is applied to the voice-port or the pots dial-peer.
Let me know, Avner.
Would anyone have an example of how to accomplish this? I believe I'm running into this same issue today.
When I have the following in my config my incoming DID's work but forwarding to CUE fails:
dialplan-pattern 1 7815775... extension-length 3 extension-pattern ...
When I remove this dialplan-pattern my incomming DID's fail but internal forwarding to CUE works just fine.
Attached is the rest of my relevent config:
- Nate
