Alejandro Corte... Wed, 09/12/2007 - 06:09
  • Silver, 250 points or more
that works fine, justo be sure that the antenna that you are using is 2.4 Ghz and is in the right side, cus the 5 Ghz must be plug the two conectors.
Usually the AP in one side says "PRIMARY", you must plug the antenna there.
