09-12-2007 06:11 AM - edited 03-14-2019 11:30 PM
I am working with a customer who is implementing two PRI?s for PSTN access. My questions are;
a) is NFAS really necessary with only two PRI?s, if so, what configuration does the telco have to do to support this
b) if I don?t use NFAS, what is the best configuration to use on the router and CCM
Gateway will be H.323 and CCM 5.1
Solved! Go to Solution.
09-12-2007 07:20 AM
Correct, since the PRIs are going to terminate on the same PRI you will only have one GW in CM.
So, there are couple of ways to make this work:
1. use seperate dial-peers with preference command defined
2. Create a trunk group and associate the trunk group with the voice-ports and dial-peers
Chris
09-12-2007 06:55 AM
a) you will only gain one B channel with 2 PRIs, in my opinion it's not worth it.
b) NFAS is supported with H.323, not with MGCP here is a config doc:
If you dont want to use it work with TELCO to bundle the 2 PRIs into a trunk group, so calls can come in to either one of the circuits on the inbound side. For outbound calls place both GW into the same Route Group, and that's it.
HTH,
Chris
09-12-2007 07:10 AM
Okay, so I am not going to use NFAS.
When you say, "For outbound calls place both GW into the same Route Group, and that's it."
If using H.323, won't I just have one gateway in CCM?
Thanks for the reply!
09-12-2007 07:20 AM
Chris
