MWI request is pending On
Sep 12th, 2007
Hi All,
I have Cisco Unity 4.0 Build 4.0(4) SR 1.
I tried to send the Voice mail to one of the Subscriber. Subscriber received the Voice message.But MWI status was showing "MWI request is pending On". Also there was no notification on the phone of the subscriber (Red light was not glowing on the phone.)
Need help to resolve the problem.
Hemant
Tommer Catlin Fri, 09/14/2007 - 10:45
  • Green, 3000 points or more
Does the MWI pending match the subscriber extension?
From the IP phone that is having the issue, try dialing the MWI ON extension, if the light turns on, you are ok.
In Unity, it is possible the subscriber MWI is out of sync. You will need to clear all new voicemails from the box, then try to leave a message again.
Or, you can you delete the MWI extension, disable, re-enable it, and sync it again.
This will reset the subscriber MWI status is SQL and Exchange
hemant.wavhal Mon, 09/17/2007 - 02:38
The moment i change the partition of the phone MWI is sent properly to the phone.
Red light glows. The moment i put this phone in different partition, Red light goes off.
In Unity server, the subscriber's setting for MWI shows: MWI is pending ON.
Please suggest.
Tommer Catlin Mon, 09/17/2007 - 06:46
Placing a phone in a partition does turn on MWI lights all by itself. If the extension you are using is the same as the MWI extension for "on" or "off" that could be a problem.
put the phone in a partition
dial the MWI extension for "on" to make sure the phone can in fact be turned on for MWI and also off.
Make sure you have cleared all voicemails from the users account (or listend to all new messages.)
Delete the MWI extension or completely remove MWI from the subscrbiers
Save
Now re-enable the MWI with an "X" in the extension box.
MWI should say off
Now leave a message for the subscriber. Light come on?
Also, does the extension match the subscribers voicemail extensions? if not, then you are doing some sort of voicemail profile with a "mask"
