using public ip addresses on dsl router
Sep 12th, 2007
Hi all if I have been assigned 5 public ip addresses to my dsl router but want the ethernet interface to be on one of them, would I put the ethernet interface on one of the public ip addresses and then use ip unnumbered for the dialler interface, is this like bridging the connection ?
spremkumar Wed, 09/12/2007 - 19:05
hi carl
can you confirm whether the ips have been assigned and routed properly at SP end ?
Also can you post the config out here ?
Generally you will get the ip assigned either dynamically or assigned statically from the SP WAN pool.
is that not the case with your setup ?
