Cisco Client VPN routing Issue
I have cisco pix 515e with OS 7.2 on it
We have vpn client version 5 (the latest revision)
I have multiple subnets terminating a vpn off the pix and then on the
LAN behind the pix we have a router which is connected to another
couple of subnets via mpls
NOW when i vpn in with the client (after configuration) i can get to
the subnets with terminate a vpn off the pix but i cannot route to the
subnets via the router which connects to the mpls network!
I have tried adding in static routes and redistribute routes and a
couple of other things but any suggestions would be very helpful!
John
a.alekseev Wed, 09/12/2007 - 08:37
  • Gold, 750 points or more
On the router you have to have a route for vpnclient's address.
On pix, please check split-tunneling.
You nerworks behind the router must be in this split-tunneling ACL.
