mirtenmous Wed, 09/12/2007 - 11:23
Thanks but I forgot say to you that I only wanto to hide dial number for internal calls.
Do you give me the same solution now?.
Chris Deren Wed, 09/12/2007 - 11:41
Yes, use tranlsation patterns for internal calls. For example assuming you want to hide dial (not sure if you mean calling or called) number for anyone calling 4 digit dialing where your internal DNs are in the 2XXX, 3XXX range you would create a TP of [23]XXX and set the restrictions there. Make sure that the phone's CSS has only access to the Parition assigned to this TP and not to the phone PT.
Chris
mirtenmous Wed, 09/12/2007 - 23:13
Really, I want to hide 7020 dial number so I added a TP 702X with a internal partition and the correct css and in calling Party Transformations I choosed restricted Calling Line ID Presentation but when I call from 7020 dial number to other phone, dial number appear in the screen. I don't know what is wrong.
