Cisco ISR-2801 With ADVIPSVC-K9-MZ and no IDS
Sep 12th, 2007
Can someone tell me why I have some older routers with the advanced ip services images and ip audit (IDS) services work and the new ISR router with the
Advanced ip services k9 image doesnt. I went throught the software advisor and it looks like it should support audit rules and signatures with defined actions etc. I dont have any of these options. on this 12.4-12-mz image its running on. Can someone clarify why?
aghaznavi Tue, 09/18/2007 - 10:10
  • Silver, 250 points or more
Secure Sockets Layer provides security for web transactions by handling authentication, data enryption and digital signatures. The 2800 Series supports SSL VPNs and SSL acceleration via the AIM-VPN/SSL-3.
