Caller ID Name to Unity Express
m-ketchum
Is there a way to pass caller ID name from the PSTN to CUE?
I'm passing the number but not the name.
I'm receiving caller ID name via my PRI's and passing it to the IP phones.
The idea here is to not have "unkown caller" appear for external voice calls in voiceview, but rather the caller ID name received from the PSTN.
Mike
Markus Schneider
No, sorry, that's not possible.
8 Replies 8
Markus Schneider
That's unfortunate. Thanks for the reply.
mlitka
Level 2
Level 2
Mike -
If you do a debug isdn q931 you should see the Caller ID infofrmation listed. Chances are you aren't getting the name information from the PSTN.
Here is an example of the debug information from a PRI that doesn't receive Caller ID info:
Sep 12 18:40:10.461 BST: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '234160'
Plan:ISDN, Type:Unknown
Notice the calling Party Number information, the N/A should hold the Calling Party's Number.
Notice here is an example of an ISDN debug with both Caller ID and Caller ID with Name:
Sep 12 13:45:21.901 EDT: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x1C22
Bearer Capability i = 0x9090A2
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Channel ID i = 0xA98393
Exclusive, Channel 19
Facility i = 0x9F8B0100A10F02016606072A8648CE1500040A0100
Protocol Profile = Networking Extensions
0xA10F02016606072A8648CE1500040A0100
Component = Invoke component
Invoke Id = 102
Operation = InformationFollowing (calling_name)
Name information in subsequent FACILITY message
Calling Party Number i = 0x2180, '8595551212'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '8005551212'
Locking Shift to Codeset 6
Codeset 6 IE 0x28 i = 'Doe, Jon'
Sep 12 13:45:21.993 EDT: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8 callref = 0x1C22
Facility i = 0x9F8B0100A115020167020100800D4B454E5455434B592043414C4C
0xA115020167020100800D4B454E5455434B592043414C4C
Invoke Id = 103
Operation = CallingName
Name presentation allowed
Name = KENTUCKY CALL
Hope that helps!
Mike
Thanks for the reply, but please re-read my initial post. Thanks.
ali.yusuf
Hi Mike
You cannot get PSTN info because the PSTN does not forward that info
Hope that helps
Sure it does...it does to my phones.
interesting.... what does it forward? unknown caller or the actual number from the PSTN?
regards
Is it possible to display the name for internal IP Phone callers? I can forward extension number but not the name of the internal caller.
