pix recovery
Sep 12th, 2007
I always have problems with password recovery on a pix. I follow the instuctions below, but always get confused.
I want to connect to the pix with a laptop via a cross over cable. I think that would be the simpliest way.
Can some one simply the procedures for me. I will not be infront of the pix and will have to instruct someone.
Any input will be very appreciated.
1cmerchant Thu, 09/13/2007 - 11:24
Not sure what you're confused about regarding the procedure detailed in the link you posted, but that is what you've got to do in order to recover a Pix password.
As for wanting to 'connect to the pix with a laptop via a cross over cable' I'm not sure what that will accomplish, as you'll need console (terminal 0) access in order to run the procedure.
Unfortunately there isn't really a way to simplify the procedure, it is what it is.
