LMS 2.6 : Adding device on DCA Slave
Sep 12th, 2007
having 2 LMS 2.6 server.
The first one as DCA Master with RME and Campus Manager
The second one as DCA Slave witch RME, Campus and CiscoView
I want to have some device managed from server 1 and other device manged from server 2
Adding device to server 1 is Ok
Adding device ti server 2 is ko, msg "The Device Management operation is not allowed on slave DCA server"
What is wrong in my configuration ?
Best regards
Gilles
Joe Clarke Wed, 09/12/2007 - 12:07
Devices can only be added to the DCR master server. Once they are added, the slave(s) will pull those device updates from the master, and replicate its device list.
If you do not want slaves to see certain devices, then you should probably not use the DCR master/slave feature. You can still make use of Single Sign On master/slave, however.
gbusson Wed, 09/12/2007 - 22:32
If i understand, i should see the same number of devices in the inventory list of the master and slave server ? In my case, i see 3010 devices on the master and 1200 on the slave (devices on the slave are also on the master).
Joe Clarke Thu, 09/13/2007 - 08:32
Is either server integrated with ACS? Which device list are you comparing?
