DFM - Env (Fan) Alerts for Non-Capable Switches(2960)
Answered Question
Sep 12th, 2007
We have quite a few 2960 (Running LAN-Base Image) that apparently do not support the OID for checking the Fan Status (1.3.6.1.4.1.9.9.13.1.4). I have run snmpwalk on this and nothing gets returned. They do support the other OIDs in the EnvMon MIB.
However DFM is apparently not smart enough to notice this and still generates an Event saying that "Fan is Not Ok". Why is that ?
I probably can add these 2960 switches into a customizable group and disable EnvMon checking but that will also disable the checking for Temp and Power ?
What could be a more decent solution for this ?
Naman
Correct Answer by Joe Clarke about 9 years 8 months ago
DFM uses the CISCO-STACK-MIB to query fan status (chassisFanStatus). It is probably returning 4 which could point to CSCsh15007. This bug was fixed in 12.2(35)SE1.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 09/12/2007 - 14:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mnlatif Thu, 09/13/2007 - 04:50
Correct. It is returning 4. I will try upgrading to the fixed version.
Thanks.
