ASA 5505 Transparent Firewall COnfiguration How To
Sep 12th, 2007
Hi Guys!
I am stuck i want to configure an ASA 5505 in transparent mode (7.x). SOmehow i got it to work.. but i need some kind of step by step description. I just wantto connect it with outside on a route .. inside in my LAn. Its working now with one ASA.. i have no idea why. But in the Web Interface the Interfaces inside and outside are down.. but its working.
So whats the correct way of configuring (from scratch) ?
THANKS
marco
Overall Rating: 3.3 (3 ratings)
rajbhatt Thu, 09/13/2007 - 01:16
Here is a lab config :
router
172.150.150.1
PIX <---- 172.150.150.2
172.150.150.3
inside router
pixfirewall(config)# sh run
: Saved
PIX Version 7.0(1)
firewall transparent
names
interface Ethernet0
nameif outside
security-level 0
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
no security-level
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
ftp mode passive
access-list outside_in extended permit icmp any any
access-list outside_in extended permit tcp any host 172.150.150.3 eq telnet
no pager
logging console debugging
ip address 172.150.150.2 255.255.255.0
no failover
monitor-interface outside
monitor-interface inside
access-group outside_in in interface outside
route outside 0.0.0.0 0.0.0.0 172.150.150.1 1
kmmehlkmmehl Fri, 09/14/2007 - 23:20
hi
thanks
what about the vlans? i tried this but then it says i needtohave vlans configured...i cant see that in your config! (inside / outside)
a.alekseev Sat, 09/15/2007 - 02:50
  • Gold, 750 points or more
firewall mode transparent
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Ethernet0/0
switchport access vlan 2
no sh
interface Ethernet0/1
no sh
interface Ethernet0/2
no sh
interface Ethernet0/3
no sh
interface Ethernet0/4
no sh
interface Ethernet0/5
no sh
interface Ethernet0/6
no sh
interface Ethernet0/7
no sh
access-list OUTSIDE-IN permit ip any any #you can permit something what you want
access-group OUTSIDE-IN in int outside
E0/0 - connected to the router
E0/1 -7 connected to your LAN
jayakireetikesani Tue, 11/06/2012 - 14:15
Hi, I need help in configuring Transparent Firewall in my ntwrk.
Setup:
Router
ASA
Switch
My question is:
In my original setup i dont have any ASA. Now we would like to insert an ASA in middle.
We have sub interfaces on the router for different vlans. Now when I configure vlans on ASA for inside and outside and assign to Ethernet interfaces, will the ASA allow traffic which are with different vlans.
Should I assign the interface connectd to router as Trunk or will this work.
My router has the below interfaces
EEIPL-RTR-1#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.242        10.28.242.1     YES NVRAM  up                    up
FastEthernet0/0.243        10.28.243.1     YES NVRAM  up                    up
FastEthernet0/0.244        10.28.244.1     YES NVRAM  up                    up
FastEthernet0/0.245        10.28.245.1     YES NVRAM  up                    up
FastEthernet0/0.246        10.28.246.1     YES NVRAM  up                    up
Will my basic ASA transparent firewall config will allow the traffic.
ASA config:
interface vlan 1
nameif inside
interface vlan 2
nameif outside
interface eth0/0
switchport access vlan 1
interface eth0/1
Please do reply ASAP.
