Migartion from CM 4.2(1) to CM5.1.2
Sep 13th, 2007
From the cco i have found that its not possible to migrate a callmanager 4.2.1 with a data migration tool to callmanager 5.1.2b. Can any ony confirm this.
Many thanks
Rob Huffman Thu, 09/13/2007 - 05:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Patricio,
Sadly, you are correct :( There is no Upgrade path from the CCM 4.2 Train to any 5.x Release. This nice new Tech Note document shows a good visual of the supported Upgrade paths (CCM 4.2 can go directly to CCM 6.x)
Cisco CallManager Upgrade Paths
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008086cc7c.shtml#topic2
Hope this helps!
Rob
