UC500 Series question
Answered Question
Sep 13th, 2007
Can UC500 be used as a total solution ( ie routing + voice ) for a remote branch ?
In other words , does routing also buit-in for this box ?
Correct Answer by anderson-david about 9 years 9 months ago
sorry no it can't, if you need WAN connectivity you will need a seperate router for this
I hope this helps
Overall Rating: 5 (1 ratings)
Correct Answer
anderson-david Thu, 09/13/2007 - 01:51
I hope this helps
Majdi Harb Thu, 09/13/2007 - 02:13
  • Silver, 250 points or more
Hi nkariyawasam
the UC500 system has a WAN uplink (10/100 Mbps) available. and this uplink can be used to provide connectivity into the broadband infrastructure (DSL modem, existing ISR or other data network set-up).
so you have to get a seperate data network setup box.
hth
/majdi
