09-13-2007 01:35 AM - edited 03-03-2019 06:44 PM
Hi Experts,
I am puzzling with this..I have this router eigrp config as below but is WITHOUT Router RIP command. So, what is the command " redistribute rip metric 15000 500 255 1 1500 " for if that is the case?
router eigrp 10
passive-interface default
no passive-interface Serial2/0
no passive-interface Serial2/1
no passive-interface Serial2/2
no passive-interface Serial2/3
network 13.31.0.0 0.7.255.255
auto-summary
Thanks in advanced!
Solved! Go to Solution.
09-13-2007 01:49 AM
that is correct.
if in doubt use
sho ip route summ
this will show you all routing protocols in use and prefixs.
09-13-2007 01:41 AM
I would have a guess and say nothing. Its often the case commands like this are left in after clean ups or migrations and someone didnt take it out.
If no routing process is running then the redist command will not perform a function on that named process unless it exists.
09-13-2007 01:44 AM
If RIP is not being used, you can go ahead and remove this configuration
Narayan
09-13-2007 01:44 AM
Thanks Robert! for your quick response!! :D
,can i say even another router connected to the core switch together with this router having RIP, this command doesn;t serve any purposes on this particular router?
09-13-2007 01:46 AM
Thanks Narayan! :)
so, the same question will be what i posted to Robert..If that is the case, i can proceed to remove this and if there is "redistribute static metric" but NO STATIC ROUTE Existed,
i can also remove this command rite? ;)
Thanks.
09-13-2007 01:51 AM
Yes you are correct
Narayan
09-13-2007 02:10 AM
Thanks guys..
post rated!! :D
09-13-2007 01:49 AM
that is correct.
if in doubt use
sho ip route summ
