09-13-2007 02:35 AM - edited 03-10-2019 03:47 AM
Login onto the console works fine but although the front page appears there is no information and no drop down menus has anyone got any ideas
Database is up and running
09-13-2007 10:25 AM
Have you restarted the MC? Are you logging in locally or remotely? If remotely, have you tried from different machines?
Try the logging in locally on the MC console if you haven't already.
09-17-2007 01:07 AM
Thanks for that but I have tried all your suggestions still no luck
I am contemplating rebooting the server.
09-20-2007 03:16 PM
Restarting the server is what I had in mind when I said restart the MC. Did you try that yet?
Jean-Pierre may also be on to something with the Java/Browser.
You should check the Console from several different versions and machines.
Tom
09-20-2007 11:47 PM
I have tried from numerous different client workstations, i still have the same result ie no real access. I have now rebooted the server and all is now working. I have checked the rule generation and that appears fine, Will have to put it down to a "glitch"
Thanks for you responses
09-18-2007 06:16 AM
could this be a Java/Browser issue? What are you using ?
