Access-Group
linker.team
Basically, there would be "access-group" under which there would be multiple "rules" listed. This "access-group" would be then applied on desired interface.
When some transactions matching them generated a message is logged with the "access-group" (ex: PIX-4-106023).
Is it possible to get the exact rule within the "access-group" that matched ? If so do let me know.
thanks,
-S-
micheljoh
Well hum
you have an access-list specified on the access-group
like:
access-list Web-Trafic permit tcp any any eq 80
and then an access-group applied to you interface:
access-group Web-Trafic in interface outside
if you need to know what hit the "access-group" look at the access-list by:
sh access-list Web-Trafic
you would get something like:
access-list Web-Trafic; 1 element
access-list Web-Trafic line 1 extended permit tcp any any eq 80 (hitcnt=11)
this would meed 11 hits on that access-list wich is applied to the access-group.
Regards//Michel
Hi Michel,
Appreciate your reply. Your suggestion would get the total hits for the rule defined with-in the group.
Consider the below case (some sample rules),
access-list outside_access_in; 2 elements
access-list outside_access_in line 1 permit tcp x.x.x.x 255.255.255.0 any (hitcnt=0)
access-list outside_access_in line 2 deny tcp any any eq FTP (hitcnt=0)
Now, assume we have a transaction matching rule 2. I would love to see the exact rule along with Source-Destination combination in the logs. Like connection from source X to destination Y was dropped as rule "outside_access_in line 2" doesn't permit.
Is this possible ? Pix is giving the group name & not the exact rule within it. Hope i am clear with my requirement :-( .
thanks,
-S-
Well if i do understand you correctly what you could do is put a log level at the end of the second rule
Example:
access-list outside_access_in line 2 deny tcp any any eq FTP log errors
and then logg for example to to buffer:
conf example:
logging on
logging buffered errors
if you whant a larger buffer use:
loggin buffered-size ?
Although using this will only hit on sources going to ftp not being sourced from your x.x.x.x 255.255.255.0 network
since ftp from that network is being allowed on line 1
You can also use the logg message id and logg that to either syslog or buffer
Regards//Michel
To my knowledge, this has always been a shortcoming with logs. It shows a log entry with the ACL name, but not the line number it matched. Send cisco an enhancement request. maybe they will finally add this. I have asked for it before.
