09-13-2007 04:17 AM - edited 03-18-2019 07:49 PM
Hi.
I'll be upgrading a Unity UM Box running 4.0(5) to 4.2(1) on same box. Do I need to update the schema master on the AD? The reconfiguration and upgrade guide of 4.x mentions that but I'm not sure if it does changes to the AD after the 4.0(5) changes.
Thanks in advanced,
-Jose
09-13-2007 05:30 AM
Yes there are changes, not many, but you do need to run the schema update.
rlp
09-14-2007 10:38 AM
yes, backup DIRT, update the schema, update the Exchange Tools, the install 4.2 inplace upgrade.
Should be good to go.
