QoS on New Cisco 3825 Router
Sep 13th, 2007
I recently replaced a Cisco 3640 Router with a new Cisco 3825 Router. We use multiple T-1 Circuits (IMA) for WAN connectivity.
The partial configuration for the ATM setup is as follows:
interface ATM1/0
description ATM CIR 1
no ip address
atm vc-per-vp 256
no atm ilmi-keepalive
ima-group 0
no scrambling-payload
interface ATM1/1
description ATM CIR 2
no ip address
atm vc-per-vp 256
ima-group 0
interface ATM1/2
description ATM CIR 3
no ip address
atm vc-per-vp 256
ima-group 0
interface ATM1/3
description ATM CIR 4
no ip address
atm vc-per-vp 256
ima-group 0
interface ATM1/IMA0
no ip address
no ip route-cache cef
atm vc-per-vp 256
no atm oversubscribe
atm uni-version 3.1
no atm auto-configuration
no atm address-registration
no atm ilmi-enable
interface ATM1/IMA0.44 point-to-point
ip address 111.222.333.444 255.255.255.252
pvc ABC 1/44
vbr-rt 6000 6000
oam-pvc manage 0
encapsulation aal5snap
service-policy output IPATMCOS
I have a policy-map assigned under pvc on Interface ATM1/IMA0.44.
On the new Cisco 3825 Router, I have the following configuraton:
interface ATM0/IMA0
no ip address
atm uni-version 3.1
no atm ilmi-enable
interface ATM0/IMA0.44 point-to-point
pvc ABC 1/44
vbr-rt 6000 6000
oam-pvc manage 0
interface ATM0/0/0
description WAN CIRCUIT 1
no ip address
ima-group 0
interface ATM0/0/1
description WAN CIRCUIT 2
no ip address
ima-group 0
interface ATM0/1/0
description WAN CIRCUIT 3
no ip address
ima-group 0
interface ATM0/1/1
description WAN CIRCUIT 4
no ip address
ima-group 0
When I attempt to add the Policy-Map IPATMCOS under Interface ATM0/IMA0.44, the line does not show up in the configuration.
Is there a change in 12.4 related to the placement of the Policy-Map?
I've placed the Policy-Map under Interface ATM0/IMA0, but this has no effect.
Joseph W. Doherty Thu, 09/13/2007 - 05:10
Don't know if this is your issue, but I've hit the situation where if the policy map has more bandwidth defined in it then it believes the interface supports, it will allow you to enter it at the command line, but quietly drops it (although I think I've also found it will syslog the drop).
I've also seen this behavior with any type of bundled links, if the bundle loses enough members that the bandwidth is insufficient for the policy, it gets dropped. (Policy doesn't automatically reappear when the down link member comes back on-line, either.)
If this is the issue, use bandwidth percentages, available in later IOSs, instead of absolute values, including for LLQ if defined.
christopher.morgan Thu, 09/13/2007 - 05:19
Thanks for the response. I actually have percentages in use instead of absolute values.
Joseph W. Doherty Thu, 09/13/2007 - 05:47
Nothing in syslog then?
PS:
Forgot to comment on the question about policy placement with 12.4 and ATM.
Got lots of them working on many 2811 running 12.4 and ATM under the PVC, where you would expect to place it.
