Cisco 2500 Part number ????. Kindly assisst
I am at a point of desperation. Kindly assist or point me to the right direction for assisstance. I am trying to find the Part number for the following. But can't seem to find it. Searched on Cisco and google but no luck.
SP 73-0895-04
cags_lnm#sh ver
IOS (tm) 2500 Software (C2500-IS-L), Version 12.0(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Wed 13-Oct-99 21:43 by phanguye
Image text-base: 0x0303DC40, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
cags_lnm uptime is 1 year, 4 weeks, 2 days, 20 hours, 15 minutes
System restarted by power-on
System image file is "flash:c2500-is-l.120-7.bin"
cisco 2500 (68030) processor (revision L) with 6144K/2048K bytes of memory.
Processor board ID 08919429, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash partition 1 (Read ONLY)
8192K bytes of processor board System flash partition 2 (Read/Write)
paul.matthews Thu, 09/13/2007 - 06:15
It might be easier if you describe what you need a PN for - for example one of the items you mention is a token ring port adapter, which is not related to a 2500.
If you are looking for the flash, try MEM-1X16F amd MEM-1X8F.
BTW you are on obsoete hardware, and positively ancient software!
alindh Sun, 09/16/2007 - 10:39
As you already have the part numbers, I assume you want to know what they are:
MEM-RP-FLC16MB, looks like an old 16meg linear flash card (not ATA).
PA-4TR: 7200 card, but not a valid part. Could be a PA-4R token ring or a PA-4T sync serial card.
73-0895-04, SP card for 7000 router.
The router with "sh ver" looks like a 2514
The whole lot has no cash value...I had no problem finding them with Google. You need to improve your searches.
