QOS on new 2801 network users use IPC
Sep 13th, 2007
My client has a router 2801 and a switch 3750. There will be 25 users using IP Communicator for voice. No actual IP phones. So i guess that would be utilzing the bandwidth like data traffic.
THe router has a connection to an Adtran that goes to an MPLS network. And a connection to a firewall.
Attached are the configs.
It might just be either NO QOS needed or a very simple QOS configuration. Either way, i am just looking for some suggestions or some sample qos setup for what I need.
Thanks in advance
royalblues Thu, 09/13/2007 - 07:49
If you are looking for just Qos on the LAN you can just trust the dscp received on the port.
mls qos
mls qos map cos-dscp 0 8 18 26 34 46 48 56
interface fa 1/0/1
mls qos trust dscp
On the router
class-map match-all voice
match ip rtp 16384 16383
policy-map QoS-to-MPLS
class voice
priority 1024
set ip dscp EF
class class-default
interface fa 0/1
max-reserved-bandwidth 100
service-policy output QoS-to-MPLS
Narayan
shirwaziri1_2 Thu, 09/13/2007 - 08:02
What does this mean:
mls qos trust dscp
(QOS newbie)
Also, on the router, what will that do, what will be the priority? Since they use softphones they shouldn't need anything special for voice right? Just trying to make some sense of what you provided.
thanks for your help though...
royalblues Thu, 09/13/2007 - 08:17
DSCP - differentiated service code point is a per hop QoS behavior which maps a 8 bit DS QoS field in the IP packet header
By default the cisco phone/communicator would tag the voice packets with DSCP 46 and the signalling with DSCP 24. When you enable QOS and use the above command, you are trusting the values that is being set.
Narayan
