Add CUPC to UC 6 Device NameRequired Field problem
Sep 13th, 2007
I'm getting the following error, if I try to add a CUPC
Update failed. [491] TypeDbErrors.INVALID_PRODUCT_NAME
the name is only 8 chars long CUPCtest. Any other name also fails.
anyone had this problem before?
Thanks in advance
gertjan.francois Tue, 12/18/2007 - 05:42
In my opinion that is not correct. You should insert the
UPC. Be sure you insert the username in CAPITALS. otherwise it will not work
