CCM setup questions
Sep 13th, 2007
Hello all,
I have a basic setup question. I am a newbe when it comes to this part of CCM configs. I am setting up a single CCM and Unity system that will service 4 remote sites connected by WAN. Each site will have its own PSTN GW configured in CM
My goal is as follows,
1. All phones should be able to 4 digit dial all other phones at other sites internally
2. At each site when an off net call is placed, it will route out the sites local PSTN GW.
What would be the best way to accomplish this and give me the ability to add sites in the future?
Any ideas and links to examples would be helpful
Overall Rating: 5 (1 ratings)
gogasca Thu, 09/13/2007 - 12:46
  • Green, 3000 points or more
Hi!
Check out our design guide:
Cisco Unified Communications SRND Based on Cisco Unified Communications Manager 6.x
Cisco Unified Communications SRND Based on Cisco Unified CallManager 5.x
Cisco Unified Communications SRND Based on Cisco Unified CallManager 4.x
http://www.cisco.com/go/srnd
and this link should be helpful:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f54af.shtml
AJAZ NAWAZ Fri, 09/14/2007 - 21:57
  • Silver, 250 points or more
The links posted by Gogasca are perfect : )
The key to growth will be your dial-plan - start first here imo. IP-addressing provides us with a similar analogy in terms of routing that is though.
From the SRND here is the link to implementation guide for dial plans
<http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806375f2.html>
hth,
Ajaz
