vg224 recommendation for fax passthrough , and srst
Sep 13th, 2007
I have a vg224 running mgcp and it works great. Howerver we have also requierments to configure the vg224 also with srst. I read through the posts that sccp works with srst but has issues with fax passthrough.
If I wanted to keep the mgcp configuration and utilize srst is there a sample config. any issues you guys ran encountered?
bwilmoth Wed, 09/19/2007 - 08:37
If the link is broken between MGCP and the CCM the VG 224 will not be able to do fax capabilities. If you configure VG224 with a H.323 load ,VG224 defaults to H323 if it loses its MGCP link to CCM . VG 224 will register to the SRST Gateway as H323 devices and therefore be able to negotiate fax capabilities.
