Sep 13th, 2007
Does anyone know of any repercussions of using the redistribute command in OSPF while having a default route configured?
Overall Rating: 4 (2 ratings)
royalblues Thu, 09/13/2007 - 13:17
Default route will not get redistributed into OSPF unless you configure the default-originate command
SO if you want to redistribute routes into ospf except default, you can go ahead without configuring the above command
JORGE RODRIGUEZ Thu, 09/13/2007 - 13:19
Manuel, you did not specifed what you are trying to redistribute to but if you are refering to redistribute static routes I have not seen any repercussions when the device is participating in OSPF while you have defined gateway of last resort for that device by static means.
