09-13-2007 12:30 PM - edited 02-21-2020 10:19 AM
I just recently installed the eval version of ACS 4.1(1) Build 23. I also downloaded the same version of the remote agent and loaded that on a domain controller so I can authenticate against my AD. However, when following the directions to configure the remote agent on ACS I run into a problem.
The online instructions tell me to click on Network Configuration and click on "Add Entry" in the Remote Agents table. The problem is that I don't see a Remote Agents table within my Network Configuration page. What am I doing wrong?
Thanks in advance,
Nick
Solved! Go to Solution.
09-14-2007 07:08 AM
Nick,
You have acs running on windows server , so there is not need to have remote agent installed.
Remote agent is needed with acs appliance and not with acs windows.
~JG
Please rate if helps
09-14-2007 05:32 AM
Nick,
It should be under NDG.
ACS--->Network configuration---->NDG--->RA
~JG
09-14-2007 06:59 AM
09-14-2007 07:08 AM
Nick,
~JG
