SIP - Unable to find load - Constant restart
Sep 13th, 2007
I am having a problem getting a SIP phone to use it's current load and/or upgrade it's load. The error message is "Load not Specified" This is what I have in my SIPDefault.cnf
image_version:POS30704 ;
proxy1_address:192.168.2.201
proxy1_port:5060
proxy_register:1
I've tried several methods of the naming convention like POS3-07-4-00 .
The OS7 file has: P003-07-4-00
It keeps rebooting after it reads the SIPDefault.cnf
paolo bevilacqua Sat, 09/15/2007 - 04:10
  • Hall of Fame,
    Founding Member
Hi, the phone may be looking for XML config file and expect load and other settings to be in there.
Hope this helps, please help if it does!
AJAZ NAWAZ Fri, 09/28/2007 - 06:22
  • Silver, 250 points or more
I have just done this conversion couple of days ago. Tell me the complete list of files you have for SIP?
P0S3-07-4-00 <- this is correct format for image version value in SIPDefault.cnf file. You can try to put a space after the last '0' if it doesn't work. Within this file i.e. SIPDefault.cnf you can change this parameter only - no need for proxy or other settings - just leave it as-is but of course modify image version as mentioned above. For SIP specific configuration settings - use SIP.cnf
let us know how you get on.
Ajaz
