Can Cisco VPN Client 5.0 be customized?
Sep 13th, 2007
Is it possible to create a customized Cisco 5.0 VPN client, using my own corporate branding, similar to how I was able to do using the Installshield version of the 4.8 VPN client? I understand that the 5.0 installer only uses MSI now, so I'm trying to figure out if that ability to "brand" the VPN client is now gone?
tstanik Wed, 09/19/2007 - 13:28
  • Bronze, 100 points or more
You can customize the MSI installer of VPN client. Copy your oem.ini file, the custom PNG files, and the custom icons to your distribution media, for example a CD, placing them in the same directory as the vpnclient_en.msi file. Use a transform to install the VPN Client, the oem.ini file, PNG files, and icons, along with the VPN Client files during installation.
