09-13-2007 06:09 PM - edited 03-03-2019 06:45 PM
I have 2 Cisco 2821's. Each have 2 VWIC-2MFT-T1-D1 Dual T1 cards in them. I am trying to install a single interface HWIC-1FE card as a management interface. The cards light up but are not seen by the router. Is this configuration supported by this router. I currently have 3 T1's per router and want to be able to install a 4th in the future. Please let me know if I left anything out needed to answer my question. IOS is Version 12.4(13b), RELEASE SOFTWARE (fc3).
09-13-2007 07:23 PM
Mike , based on this doc the HWIC-1FE is not supported on the 2820 platforms.
[EDIT]
Sorry, I take previous note back.. you have 2821.. you seem have have minimun IOS requirements and one available slot for your the card, it could be your running IOS version.
09-14-2007 02:53 AM
Mike,
Go to software advisory and pick "find software compatible with your hardware"
HWIC-1FE is not found for use in any of the 4 slots of the 2821, but the link I posted previously is listed as a supported hardware on the 2821, I would advice you to open a TAC case to be certain.
http://www.cisco.com/public/sw-center/
