stephan.steiner Fri, 09/14/2007 - 01:48
Download the IP Phone SDK and look at the push2phone example.
Your next question will probably be how to get the IP address of a phone.. to do that you need to resort to cli commands on the cme (not the topic of this subforum), which you can send to the router via routerxml (http://www.cisco.com/cgi-bin/dev_support/access_level/product_support select "callmanager express")
preethapious Sun, 09/16/2007 - 20:48
Is it possible to send text message to group of Cisco IP phones connected to CME through HTTP POST using CiscoIPPhoneExecute and RTPMRx and RTPMTx commands
Preetha
preethapious Mon, 09/17/2007 - 02:25
Could u pls tell in detail how to send text msg to group of IP phones connected to CME using CiscoIP phone XML objects and URIs
Preetha
stephan.steiner Tue, 09/18/2007 - 22:46
Did you download and install the SDK and look at the example I mentioned? If so, what exactly did you not understand from the sample code? From your question, I do not know which part you did not understand.
preethapious Tue, 09/18/2007 - 23:38
i have to use CiscoIP phone XML objects and URIs to send msg to group of phones. so could u please suggest me based on that.
stephan.steiner Wed, 09/19/2007 - 00:41
I really don't like repeating myself. Please get the SDK and have a look at the example. It illustrates how you send any XML object to a phone. Then it's just a matter of sending to multiple phones (which is a sequence of the operation "send to one phone"). I'm quite convinced that if you study the example, things will become clear to you.. it really is quite a basic thing and the example is easy to understand and more effective then somebody giving you a basic course on pushing data to IP phones here in the forum.
preethapious Wed, 09/19/2007 - 01:59
i know how to send msg to one IP phone. what i wanted to know is how to send to zone paging group. would anyone suggest how to do text to speech paging
msabir Tue, 10/02/2007 - 10:53
If you want to send audio/text to a group of phones, you can use HTTP POST along with multithreading in Java.
