Help to move a simple CSS design to an ACE
Sep 13th, 2007
Hi, I have a production system on a CSS11503, and the service will be moving to an ACE shortly. I'm nost sure how to convert a couple of "features" of the CSS configuration.
1. WebDAV support: I had to add the extra HTTP methods;
http-method parse RFC2518-methods
http-method parse user-defined-method POLL
http-method parse user-defined-method SEARCH
http-method parse user-defined-method SUBSCRIBE
http-method parse user-defined-method BMOVE
http-method parse user-defined-method BCOPY
http-method parse user-defined-method BDELETE
http-method parse user-defined-method BPROPPATCH
Do I still need to and how do I?
2. The stickiness: It is done with an arrowpoint thingy.
content HTTP-80
add service Online-1-80
add service Online-2-80
add service Online-3-80
add service Online-4-80
protocol tcp
port 80
vip address x.x.x.x
advanced-balance arrowpoint-cookie
balance aca
active
How do I acheive the same with the ACE.
I also intend to use HTTPS in the front, talking to HTTP backend. The balancing should not be affected by this, as the ACE can see the cookies etc.
Anyone able to guide me on this setup.
Thanks.
Gilles Dufour Fri, 09/14/2007 - 02:07
  • Cisco Employee,
1. not required with ACE
2. The equivalent of arrowpoint-cookie in ACE is cookie insert.
More info on the cookie insert @
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_command_reference_chapter09186a0080685364.html
Finally for SSL termination look @
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_guide_chapter09186a008068816c.html
If you need additional help, do not hesitate.
Gilles.
