basic ACL VNC question
We have a test network that is partitioned off the production network via a routed connection and ACLs.
But a VNC session needs to be allowed from the test network to production network AND from production to test network.
The ACL will have to be 'any source' and 'any destination' networks, and I was going to use an INbound and an OUTbound ACL on the same interface from/to the test network (ie with a destination port eq 5900).
For example:
ip access-group 100
permit tcp any any eq 5900
deny ip any any
But if I apply above ACL to the egress/ingress interface to the test network, it will stop VNC traffic altogether (ie because there will not be a match for VNC data for the return conversation (will not match port 5900)).
Without purchasing a firewall, is there anyway I can apply a VNC ACL BOTHWAY filter.
Thanks in anticipation.
Overall Rating: 5 (1 ratings)
Pavel Bykov Fri, 09/14/2007 - 00:36
Try this instead:
ip access-list extended VNC-LIST
permit tcp any any range 5900 5910
permit tcp any range 5900 5910 any
permit tcp any any range 5800 5810
permit tcp any range 5800 5810 any
permit tcp any any range 5500 5510
permit tcp any range 5500 5510 any
and apply it both ways.
This ACL is per this document:
It allows up to 11 VNC sessions to any machine, and it allows communication BOTH WAYS (you have allowed only one way communication).
Hope this helps.
Please rate all helpful posts.
