OSPF down due to Retransmission Error
Sep 14th, 2007
  • Bronze, 100 points or more
We have one downstream location connected on NSSA. OSPF neighborship between ABR and downstream router is getting flucutated. In "sh log" in ABR, i'm seeing the reason being "too many retransmissions"...
%OSPF-5-ADJCHG: Process 10, Nbr x.x.x.x on Serial1/0 from FULL to DOWN, Neighbor Down: Too many retransmissions
%OSPF-5-ADJCHG: Process 10, Nbr x.x.x.x on Serial1/3 from FULL to DOWN, Neighbor Down: Too many retransmissions
%OSPF-5-ADJCHG: Process 10, Nbr x.x.x.x on Serial1/6 from FULL to DOWN, Neighbor Down: Too many retransmissions
%OSPF-5-ADJCHG: Process 10, Nbr x.x.x.x on Serial1/3 from DOWN to DOWN, Neighbor Down: Ignore timer expired
%OSPF-5-ADJCHG: Process 10, Nbr x.x.x.x on Serial1/6 from DOWN to DOWN, Neighbor Down: Ignore timer expired
What could be the reason? Can anyone advise some work around for this ??
thomas.anthony Fri, 09/14/2007 - 00:17
you may need to check the MTU and physical counter parameters on interfaces connecting
OSPF neighbours - most likely causing this behaviour
check the bandwith as well
