TCP packet with SYN flag sets and windows size equal to zero
Sep 14th, 2007
I am running software version 7.2(2) on an ASA5510.
I have configured the appliance in transparent mode to filter traffic from the wireless lan ( connected to the outside )
to the wired lan ( connected to the inside ). In this first test phase I configured my ASA5510 to permit all the ip
traffic between wireless lan and wired lan :
access-list IN extended permit ip any any
access-list OUT extended permit ip any any
access-group OUT in interface outside
access-group IN in interface inside
My wireless terminals use a private protocol, called 9010t, to communicate with the application server. This protocol
opens a TCP session to the application server using a packet with the SYN flag sets and the Window size equal to zero.
This first TCP packet is discarded by the ASA5510, in my opinion because the ASA5510 recognises it as a malformed packet,
and wireless terminals can't connect to the application server.
Is it possible to manage the ASA5510 to permit this first TCP packet to cross the ASA5510 itself, granting wireless
terminals to connect to the application server ?
Thanks in advance for your help.
Andrea
a.alekseev Fri, 09/14/2007 - 08:21
Which tcp port numbers do your private protocol, called 9010t, use?
andreafbr Sun, 09/16/2007 - 23:00
the application server of the 9010t protocol ( created by Teklogix ) is listening on the 9999 tcp port.
Thank you for your help !
a.alekseev Mon, 09/17/2007 - 01:11
Try to indentify the root cause of your problem.
Do you have any messages on the asa/pix?
Try enable logging.
# for telnet/ssh
conf t
logg on
logg mon 7
term mon
# for console
conf t
logg on
logg con 7
Do you have "nat-contol" or "no nat-control"?
andreafbr Tue, 09/18/2007 - 03:50
during test phase I enabled both logging and packet capture. In particular the capture shows :
ASA-SMICHELE# sh capture
capture ASP-DROP type asp-drop all [Capturing - 190100 bytes]
capture ACL-OUT type raw-data access-list TEST interface outside [Capturing - 4048 bytes]
capture ACL-IN type raw-data access-list TEST interface inside [Capturing - 583 bytes]
ASA-SMICHELE#
ASA-SMICHELE# sh capture ACL-IN
4 packets captured
1: 06:25:19.211933 172.16.58.15.137 > 172.16.255.255.137: udp 50
2: 06:25:19.962016 172.16.58.15.137 > 172.16.255.255.137: udp 50
3: 06:25:20.712029 172.16.58.15.137 > 172.16.255.255.137: udp 50
4: 06:31:38.388575 172.16.58.15.138 > 172.16.255.255.138: udp 201
4 packets shown
ASA-SMICHELE#
ASA-SMICHELE# sh capture ACL-OUT
49 packets captured
1: 06:23:32.410928 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
2: 06:23:39.080135 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
3: 06:23:49.760580 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
4: 06:24:01.766241 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
5: 06:24:07.829531 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
6: 06:25:19.212055 172.16.58.15.137 > 172.16.255.255.137: udp 50
7: 06:25:19.962032 172.16.58.15.137 > 172.16.255.255.137: udp 50
8: 06:25:20.712045 172.16.58.15.137 > 172.16.255.255.137: udp 50
9: 06:27:16.093501 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
10: 06:27:21.658886 172.16.58.80.3083 > 172.16.58.15.9999: P 160698610:160698617(7) ack 806354767
win 4096
where 172.16.58.80 is the IP address of one of the wireless terminals and 172.16.58.15 is the application server IP address.
As you can see from the output of the capture there's no evidence of the first TCP packet with SYN flag sets
from the wireless terminal to the application server. Anyway I'm sure that this TCP packet starts from the
wireless terminal to the application server because I can see it through a Wireshark session on my PC
( plugged in an HUB device on the ethernet segment of the wireless LAN ).
The only tcp packets the capture shows me are the attempts the wireless client makes to download the server
pages ( packets 172.16.58.80.xxxx > 172.16.58.15.9999 with ack sets ).
Thank you
a.alekseev Tue, 09/18/2007 - 04:07
andreafbr,
Could you answer to my questions?
also
What do you have in connection table?
" sh conn protocol tcp long"
andreafbr Wed, 09/19/2007 - 00:21
a.alekseev,
I'm sorry but I can't do a new test until next Monday. I planned this new test next Monday morning.
Do you want to ask me something else to test ?
Thank you very much !
Andrea
andreafbr Fri, 10/05/2007 - 08:38
I'm sorry if I answer you just now to your e-mail. The ASA5510 is working with version 7.2(2) in transparent mode
and nat-control is not supported. I enabled :
logging on
logging console 7
logging monitor 7
and this is the logging output :
%ASA-6-302016: Teardown UDP connection 167 for outside:172.16.255.255/138 to i
nside:172.16.59.80/138 duration 0:02:01 bytes 201
%ASA-7-609002: Teardown local-host inside:172.16.59.80 duration 0:02:01
%ASA-7-609001: Built local-host outside:172.16.58.80
%ASA-7-609001: Built local-host inside:172.16.58.15
%ASA-6-106015: Deny TCP (no connection) from 172.16.58.80/1541 to 172.16.58.15/9999 flags PSH ACK o
n interface outside
%ASA-7-609002: Teardown local-host outside:172.16.58.80 duration 0:00:00
%ASA-7-609002: Teardown local-host inside:172.16.58.15 duration 0:00:00
%ASA-7-609001: Built local-host inside:172.16.61.111
%ASA-6-302015: Built outbound UDP connection 189 for outside:172.16.255.255/138 (172.16.255.255/138)
to inside:172.16.61.111/138 (172.16.61.111/138)
%ASA-7-609001: Built local-host inside:172.16.57.30
%ASA-6-302015: Built outbound UDP connection 190 for outside:172.16.255.255/137 (172.16.255.255/137)
to inside:172.16.57.30/137 (172.16.57.30/137)
%ASA-6-302016: Teardown UDP connection 169 for outside:172.16.255.255/138 to inside:172.16.59.119/13
8 duration 0:02:01 bytes 217
%ASA-7-609002: Teardown local-host inside:172.16.59.119 duration 0:03:40
n interface outside
%ASA-6-302016: Teardown UDP connection 171 for outside:172.16.255.255/138 to inside:172.16.63.11/138
%ASA-7-609002: Teardown local-host inside:172.16.63.11 duration 0:02:01
n interface outside
As you can see there's no evidence of a packet from 172.16.58.80/1541 to 172.16.58.15/9999 with the
SYN flag sets.
I also do the "sh conn protocol tcp long" command :
# sh conn protocol tcp long
17 in use, 28 most used
Flags: A - awaiting inside ACK to SYN, a - awaiting outside ACK to SYN,
X - inspected by service module
and I see no connections active.
So I decided to change interfaces roles : inside interface linked to the wireles lan and outside interface linked to the
wired lan. This change seems to SOLVE my problem because now wireless terminals can connect to the apllication server and
the "sh conn protocol tcp long" command presents :
#sh conn all long
26 in use, 26 most used
TCP outside:172.16.58.15/9999 (172.16.58.15/9999) inside:172.16.58.80/1284 (172.16.58.80/1284) flags
UIO idle 0:00:00 bytes 1029
Thank you for your help !!
Bye
Andrea
