Can't remove traffic-shape group... A bug?
Sep 14th, 2007
I have a 2821 router with the following configuration of one of it's subinterfaces:
interface GigabitEthernet0/0.50
description VLINK to NAS-7301
encapsulation dot1Q 50
ip address xxx.144.128.73 255.255.255.252
no ip proxy-arp
no snmp trap link-status
traffic-shape group 103 6000000 150000 150000 1000
This is what I've got after some manipulations with 2801 described later:
Router#sh traffic-shape GigabitEthernet0/0.50
Router#sh traffic-shape statistics
Acc. Queue Packets Bytes Packets Bytes Shaping
I/F List Depth Delayed Delayed Active
Router#sh traffic-shape queue
Traffic queued in shaping queue on GigabitEthernet0/0.50
Traffic shape group: 103
Queueing strategy: weighted fair
Queueing Stats: 0/1000/64/13538 (size/max total/threshold/drops)
Conversations 0/102/128 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 6000 kilobits/sec
The output of all 'sh traffic-shape ...' commands is empty except 'sh traffic-shape queue'!!
Well, may be redefining traffic shaping on this interface will help? No..It doesn't:
Router(config-subif)#no traffic-shape group 103
Router(config-subif)#traffic-shape group 103 6000000 150000 150000 1000
traffic-shape group cannot be configured when GTS has beenconfigured via Modular QoS CLI on Gi0/0.50
I can't get rid of GTS on subinterface! Doing 'no traffic-shape group 103' has no effect at all.
This problem occured after I tried to apply service-policy with CB shaping to this interface, already configured with GTS. This failed with message that it's prohibited to mix shaping with and without access-lists.
And now, when I try to apply service-policy I get this output:
Router(config-subif)#service-policy output policy_fromISP
mix of shaping with and without access lists prohibited
I can't neither remove nor change shaping on this subinterface. It's not clear if it even works properly.
IOS version is 12.4
How to remove this GTS?
Thank you
paolo bevilacqua Sun, 09/16/2007 - 15:42
  • Hall of Fame,
    Founding Member
The 'not-so-gentle' method, would be remove subif, reload. As if it's a bug, is debatable, you're already in the murky waters of an unsupported configuration.
