"DHCP Snooping" question
Answered Question
Sep 14th, 2007
If installed dhcp snooping for testing perpose on an access switch.
We have a big network but we don't need a distribution layer in our hierarchical network design model.
We have PE switches 65xx in the core and 35xx in the access layer.
I activated "dhcp snooping" from the folling link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swdhcp82.html
I'm studying to become a ccnp and also the curriculum describes the following task to activate snooping for dhcp packets:
[global]
ip dhcp snooping
ip dhcp snooping vlan vlan-range
[interface]
ip dhcp snooping trust
Unfortunately it does not as long as I disable "ip dhcp snooping information option"
The workable config look's like:
[global]
ip dhcp snooping
no ip dhcp snooping information option
[interface]
What does the command "no ip dhcp snooping information option" realy do???
Thanx for help
Correct Answer by Jozef Janitor about 9 years 5 months ago
It prevents the switch from inserting Option 82 header into the DHCP packet while forwarding.
I am not sure but afaik if this option is turned off then the upper layer switches can build the DHCP Snooping table, otherwise if the dhcp packet already contains the Option 82 header they will not build it.
Overall Rating: 5 (2 ratings)
Correct Answer
Jozef Janitor Fri, 09/14/2007 - 07:31
wochanda Fri, 09/14/2007 - 15:20
The 'information option' adds an Option-82 header which contains additional information about the host connecting to the network. This extra information consists of the Switch ID and Port ID that the user connects to.
This is usually used in service provider networks where the DHCP server desires extra information in the DHCP discovers. Unfortunately, many DHCP servers do not support the option-82 header.
Chances are your DHCP server doesn't support these headers, and this is why your hosts cannot get DHCP addresses when insertion is configured.
Will
bigbrother74 Sat, 09/15/2007 - 00:17
@ wochanda
This is very helpful answer. It explains clearly what I want to know...
Thanx for help
