BGP router reflector
Sep 14th, 2007
Please help me to compare two follows cases:
1 - Using 2 RRs within one cluster
2 - Separating it into 2 cluster, its means every router client is in two cluster different.
Which case is better in the actuel network ?
Thanks in avance
Edison Ortiz Sat, 09/15/2007 - 12:38
  • Hall of Fame,
    Founding Member
It depends on the design requirements. Do you have any diagrams and/or configs to illustrate your network a bit better ?
thotsaphon Sun, 09/16/2007 - 01:47
  • Gold, 750 points or more
Hi.
I think we use 2 RRs within one cluster for redundancy. If one went down then another one still works properly for their clients.
If you are using 2 clusters within the AS,separating clients of each clusters.
Make sure that the RRs of each clusters have a full mesh with each others.
Hopes this make some sense.
Thot
