CCM version
Answered Question
Sep 14th, 2007
  • Cisco Designated VIP,
    2017 IP Telephony
How do I check the CCM version without login in to the CCMAdmin page. I have problems login to a sub, I guess its a version problem. Please How do I get the version without the Admin page
Correct Answer by Chris Deren about 9 years 8 months ago
If it's CM 4.X and earlier you can go to registery
Software\Cisco Systems Inc\Callmanager\Patches\Patch Name
you should see something like:
4.1(3)sr4d
HTH,
Chris
Overall Rating: 4 (2 ratings)
Correct Answer
Chris Deren Fri, 09/14/2007 - 05:31
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
4.1(3)sr4d
HTH,
Chris
mchandak Fri, 09/14/2007 - 05:57
  • Gold, 750 points or more
To know what is the current version installed on the box along with all the installs the server has had, you can go to C:\Program Files\Common Files\Cisco\Logs\history.txt. This file would let details about each patch/upgrade installed on the box from the time the box was installed.
Ayodeji Okanlawon Fri, 09/14/2007 - 06:09
    2017 IP Telephony
Thank you
