pb: secure desktop with web client citrix
Sep 14th, 2007
version :
Cisco Secure Desktop Release: 3.1.1.45
VPN Concentrator 3005
client web citrix : 10.1
description :
1) Connexion SSL portal : OK
2) Secure Desktop install OK
3) connect to portal citrix and retreive msi package citrix web client : OK
4) During install msi package error occure.
Idea ???
Can I install msi package in environnent secure desktop ??
amritpatek Thu, 09/20/2007 - 11:02
Yes, you can install an msi package on secure desktop environment. The problem seems to be with the package you are trying to install or it may be with the msi installer. To confirm this you can disable the cisco secure desktop and then try to install the package. If installation fails with same error the problem may be in the package. Get a different copy of the package and try to install it.
