Site-to-Site VPN and Remote VPN Access config on same router
kelloggs4life
I have a site-to-site setup between a HQ and 2 branches. I however want to configure remote access to the HQ for offsite users who wan to connect from the internet into the LAN. The site-to-site vpn was achieved using Crypto Map policies to the interfaces. To create remote access VPN, i also have to use crypto map policy, but the cahllenge is i cannot use more than 1 crypto map policy on an interface.
Or can I? Any suggestions?
Femi
7 Replies 7
Tshi M
Level 5
Level 5
yes you can...please post your vpn config part so that i can make the right recommendations. you can remove things such as your key, peer addresses, etc.
attached are the config files for the router.
Let me know your comments and observations. I noticed that when i applied the remote VPN config, my site-to-site vpn stopped working. reason being that the crypto map policies for the fast ethernet interfaces had changed.
Femi
You have found your answer, you cannot apply different crypto map to the same interface. use the same crypto map for your site to site and your remote VPN. That is all there is to it.
As mentioned by Femi, We are also having the same problem. In any router we can only assign to one crypto map. And have use the same name for S2S & Remote access configuration. It's causing the S2S tunnel to fail.
Any ideal how to do it?
what u need to do is create same Crypto map for both the site to site and remote access.
Just use the same crypto map name
see sample below
crypto dynamic-map DYNMAP_2 10
set transform-set t_aml1
crypto map VPN-Map-1 client authentication list sdm_vpn_xauth_ml_1
crypto map VPN-Map-1 isakmp authorization list sdm_vpn_group_ml_1
crypto map VPN-Map-1 client configuration address respond
! Crypto-map is created for site-to-site tunnel1
crypto map VPN-Map-1 10 ipsec-isakmp
set peer 1.1.1.1
set transform-set ESP-3DES-SHA2
set pfs group2
match address Crypto-list
! Crypto-map is created for site-to-site tunnel2
crypto map VPN-Map-1 11 ipsec-isakmp
set peer 2.2.2.2
set pfs group2
! Crypto-map is created for Remote Access
crypto map VPN-Map-1 35 ipsec-isakmp dynamic DYNMAP_2
Femi
that was my reply few weeks ago but never got credits for it;
Refer to "no-xauth" for the authentication problems you are probably going to find
