Change ASA Firewall Address
Answered Question
Sep 14th, 2007
When I go through the ASDM manager and change the IP address of the ASA5505 unit and write to memory I get an error. Is there a way to do this via the console port? Thanks
Correct Answer by JORGE RODRIGUEZ about 9 years 5 months ago
go to enable mode and issue
no dhcpd address 192.168.1.2-192.168.1.33 inside
then configure the vlan to re-ip the interface after that is done go back to placing back dhcp pool for your inside network using your new IP subnet information, follow the pool format you removed for the IP range.
Overall Rating: 5 (1 ratings)
whisperwind Fri, 09/14/2007 - 07:08
1. Connect to the ASA
2. Enter Configuration mode
3. Enter the interface type and number
4. Enter the new ip address
5. Save configuration
This will look as follows, were x is ip address and y is mask:
asa(conf)# int e0
asa(conf-if)# ip address x.x.x.x y.y.y.y
mikros Fri, 09/14/2007 - 07:19
Here is what I typed
enable
p/w
config t
int e0 and I get and error "% Incomplete Command"
TIA
JORGE RODRIGUEZ Fri, 09/14/2007 - 07:31
please post " show interface " or follow the link I posted for complete CLI syntax.
whisperwind Fri, 09/14/2007 - 07:36
My example said e0, your ASA likely has a different interface type / number, once you determine what that is and enter it in place of my example you should be fine.
A sh run or sh interface will provide that information for you
mikros Fri, 09/14/2007 - 07:50
when I type sh run I get
Ethernet0/0 - Ethernet0/8
JORGE RODRIGUEZ Fri, 09/14/2007 - 08:10
Go to this link, you actually have to configure the ip in VLAN1 and/or VLAN2 instead of the physcal inetertace as this comes as default configuration for the 5505s
so you would do
config t
interface vlan#
http://www.cisco.com/en/US/docs/security/asa/asa80/getting_started/asa5505/quick/guide/setup.html#wpxref79743
Defaults
Two VLANs: VLAN 1 and VLAN2
?VLAN 1 has the following properties:
?Named "inside"
?Allocated switch ports Ethernet 0/1 through Ethernet 0/7
?Security level of 100
?Allocated switch ports Ethernet 0/1 through 0/7
?IP address of 192.168.1.1 255.255.255.0
?VLAN2 has the following properties:
?Named "outside"
?Allocated switch port Ethernet 0/0
?Security level of 0
?Configured to obtain its IP address using DHCP
mikros Fri, 09/14/2007 - 08:32
So after I type interface vlan1
I type ip address x.x.x.x y.y.y.y and I get an error "interface address is not on the same subnet as DHCP pool" should I disable DHCP and if so how?
whisperwind Fri, 09/14/2007 - 08:03
Well there you go, your ASA has interfaces labelled as ethernet 0/0 and so forth :-)
mikros Fri, 09/14/2007 - 08:07
I can get to Ethernet0/0 then when I type
ip address x.x.x.x y.y.y.y I get an Error "This can only be configured on VLAN devices"
JORGE RODRIGUEZ Fri, 09/14/2007 - 08:35
see my previous post.
configure the ip addresses through VLAN#
your inside vlan is VLAN1 and VLAN2 is your outside.
config t
interface vlan1
ip address x.x.x.x MASK
mikros Fri, 09/14/2007 - 08:49
I did that and thats when I get the Error "Interface Address is not on the subnet as your DHCP Pool". I believe my subnet is 255.255.255.255 is there a way to check?
JORGE RODRIGUEZ Fri, 09/14/2007 - 09:15
do this, if you are connected via console through hyperterminal do a capture-text from the terminal , do show run and save the file as config.txt ..then paste or attach the whole confiuration here.. to take a look at it.. we will need to remove the default dhcp pool configuration in order for you to configure the interface.. thats why it wil not take a different IP block because it does not match the default dhcp pool.
Correct Answer
JORGE RODRIGUEZ Fri, 09/14/2007 - 10:14
JORGE RODRIGUEZ Fri, 09/14/2007 - 13:43
Dennis, thanks for the ratings..
Also rememenber to save configuration every time you make changes at the command line by issuing " write mem " , by not doing so your config will be lost when you reboot the firewall.
Jorge
