ACE HTTP prove get - not able to contain '?' in URL?
Answered Question
Trying to put a probe together..
probe http probeElvis
interval 5
passdetect interval 10
request method get url 8888/livelink/llisapi.dll?func=LL.getlogin&NextURL=%2Flivelink%2Fllisapi%2Edll%3FRedirect%3D1
expect status 100 404
connection term forced
But when typing or pasting that URL in - when it gets to the '?" after llisapi.dll the CLI is interpreting that as a query for HELP - but i want it to be part of the string!!
Is my only choice to go to TCL scripting? I don't know how to do that! I'm a network guy!! :)
Correct Answer by Gilles Dufour about 9 years 10 months ago
use ctrl-v and then ? to disable the help and insert a ?
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Fri, 09/14/2007 - 07:04
  • Cisco Employee,
Gilles.
Sbutzek Mon, 05/05/2008 - 01:39
Hello Gilles.
is there a cance to bypass the ctrl-v into the config? The reason i ask, i genereate my configs via a script and i then copy&past the whole config on the CLI.
So i search for a solution to embed the ctrl-v into my configuration.
I hope you have an idea for me.
Sven
