Unity system transfers
Answered Question
Sep 14th, 2007
We are in the process of converting our phone system from a Nortel system over to Call Manager 5.1 with Unity 4.0. We have about 200 phones on the cisco side so far. We just switched over our main switch board. They are tied to a call handler for after hours greetings. In that greeting it states "If you now the extension you would like to reach you may dial it at any time" if the person trys to dial an extension that still lives on the Nortel side, unity can not find it because it is not releasing it back to Call Manager. Is there any way for that call handler to release all dial extensions back to CM so CM can then route the call occordingly.
Thanks in advance.
~Jeff
Correct Answer by Rob Huffman about 9 years 10 months ago
Hi Jeff,
I think you will need to look at the Restriction Table associated with the System Transfers to get calls to route back to the Nortel;
Caller System Transfer
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_administration_guide_chapter09186a0080449c12.html#wp1240433
You can modify the predefined restriction tables, and you can create up to 100 new ones. You can also add up to 100 dial strings to a table. New dial strings are automatically inserted into the restriction table as Dial String 0. Note that the order of the dial strings is very important because Cisco Unity sequentially compares a phone number to the call patterns in the restriction table, starting with Dial String 0. If a number matches more than one call pattern, the number is handled according to the first call pattern it matches.
From this excellent doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_administration_guide_chapter09186a008022cb4f.html#wp1045005
For example, if your Nortel extensions are;
7000-7999
8000-8999
You would need a;
7xxx* (Allow) Pattern
8xxx* (Allow) Pattern
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 09/14/2007 - 10:15
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeff,
7000-7999
8000-8999
You would need a;
Hope this helps!
Rob
Rob Huffman Fri, 09/14/2007 - 13:14
  • Hall of Fame,
    Founding Member
Hi Jeff,
You are most welcome :) Have a great weekend!
Rob
