Offnet to offnet transfer issue.
Sep 14th, 2007
Hi all, I have a problem with offnet to offnet transfer but only when I call an external number.
My CCM ver is 5.1.2 and the parameter offnet to offnet block are disable/false.
For example:
If someone (from extern) call me and I want to transfer to another external phone all work correct.
But if I call an external number and I want to transfer this, the call are dropped when I try to connect the external phone.
In my log I see this line:
Cause i = 0x80AC - Requested circuit/channel not available
Anyone know where is my problem
I have attached the log, and for privacy the other number are replaced with XXXX.
The interest number are EXT_1 and EXT_2 .
Thanks Enrico.
Anonymous (not verified) Thu, 09/20/2007 - 11:10
refer to these two bugs which is similar to your issue
CSCec05390
CSCeb47217
As a workaround
Shut down /no shut or clear interface should solve the problem
