4948 boot problem
Sep 14th, 2007
My 4948 box cannot get past rommon. When I
issue a reset command I get the following:
filesystem version 0x10001 is not supported**********************
Device Internal Flash Memory needs to be formatted with a newer version of IOSimage and netload?
boot: can not load "bootflash:cat4000-i5s-mz.122-25.EWA9.bin"
from IOS to poin
I have not been able to find any info on how to format bootflash:
Jim
glen.grant Fri, 09/14/2007 - 16:58
  • Purple, 4500 points or more
If you do a "dir bootflash: at the rommon prompt what does it show for an image ?
jimjudd300 Mon, 09/17/2007 - 04:59
Hello and thanks for the reply.
Here is the result of dir bootflash:
rommon 4 >dir bootflash:
dir: cannot open device "bootflash:"
