asa static nat with only one public ip
Answered Question
Sep 15th, 2007
hi netpros,
customer is using asa 5510 to connect to the internet via pppoe with one public ip on the outside interface (assigned through pppoe - static ip address).
he now wants to publish his webserver through this ip adress. webserver is on a private subnet behind the asa.
when trying to configure static nat, all request are denied with message 710003.
so the asa thinks the traffic is sent to it directly and the nat rule seems not be applied.
is this nat config with one public ip address on the outside interface generally possible?
thanks in advance.
best regards
juergen
Correct Answer by a.alekseev about 9 years 5 months ago
http://cisco.com/en/US/docs/security/asa/asa72/configuration/guide/pppoe.html
nat (inside) 1 0 0
global (outside) 1 interface
static (inside,outside) tcp interface 80 192.168.0.10 80
access-list OUTSIDE-IN permit tcp any any eq 80
access-group OUTSIDE-IN int outside
Overall Rating: 5 (1 ratings)
bauer.juergen Sat, 09/15/2007 - 03:17
thanks, its working.
tried to to this through asdm but it did not work when using the public ip in the "translated adress" field. now i can see "(Interface IP)" in this field.
thanks for the fast response and best regards
juergen
