6509 error
Sep 15th, 2007
  • Bronze, 100 points or more
Anyone seen this:
Sep 15 07:50:07.202 UTC: %MLSCEF-SP-2-FIB_SSRAM_WRITE_INCONSISTENCY: FIB SSRAM Mismatch for Index: 16386
Expected: 4000 , Hardware: 40A8
BR,
Bjornarsb
Overall Rating: 5 (1 ratings)
Edison Ortiz Sat, 09/15/2007 - 12:00
  • Hall of Fame,
    Founding Member
Let's see
show mls cef hardware
You may have to contact TAC and have the SP DRAM replaced.
bjornarsb Sun, 09/16/2007 - 06:02
#sh mls cef hardware ?
module Show for module
| Output modifiers
sw96aq#sh mls cef hardware
CEF TCAM v2:
Size:
65536 rows/device, 2 device(s), 131072 total rows
32 entries/mask-block
8192 total blocks (32b wide)
0 - 4095 upper blocks, 4096 - 8191 lower blocks
1179648 s/w table memory
Used blocks:
Upper bank:
43 IP ucast
0 IPX
2 IP mcast
Lower bank:
0 IP ucast
0 IPX
0 IP mcast
Max:
51 IP ucast
0 IPX
2 IP mcast
Free blocks (non-contiguous range):
22 - 4095 upper blocks, 4096 - 8191 lower blocks
Options:
sanity check: on
sanity interval: 301 seconds
redistribution: off
redistribution interval: 120 seconds
redistribution threshold: 10
compression: on
compression interval: 31 seconds
serialization: on
serialization interval: 16 seconds
recovery: on
recovery interval: 3 seconds
bank balancing: off
bank differential limit: 5
rpf mode: off
tcam shadowing: on
Background Task statistics:
sanity check count: 0000000000129642
Consistency check count: 0000000001252770
Consistency check errors- TCAM: 0000000000000000
Consistency check errors- SSRAM:0000000691786340
block redistribute count: 0000000000000000
IP ucast serialize count: 0000000000222322
IP mcast serialize count: 0000000000000000
IP ucast recover count: 0000000000000000
IP mcast recover count: 0000000000000000
block compress count: 0000000000041128
IP ucast [32]: 0000000000002132
IP ucast [30]: 0000000000000003
IP ucast [24]: 0000000000000080
Hardware switching status:
ip switching: on
ipx switching: off
Edison Ortiz Sun, 09/16/2007 - 08:01
  • Hall of Fame,
    Founding Member
I don't see anything wrong at the CEF table.
What IOS version and Supervisor module are you running ?
bjornarsb Sun, 09/16/2007 - 08:21
Hi again,
#sh ver
IOS (tm) s222_rp Software (s222_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Mar-06 16:59 by tinhuang
Image text-base: 0x40101040, data-base: 0x42C38000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: s222_rp Software (s222_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF4, RELEASE SOFTWARE (fc1)
sw96aq uptime is 1 year, 12 weeks, 2 days, 17 hours, 54 minutes
Time since sw96aq switched to active is 1 year, 12 weeks, 2 days, 17 hours, 56 m inutes
System returned to ROM by power-on (SP by power-on)
System restarted at 22:23:15 UTC Wed Jun 21 2006
System image file is "disk0:s222-adventerprisek9_wan-mz.122-18.SXF4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6509 (R7000) processor (revision 3.0) with 458752K/65536K bytes of memory.
Processor board ID TBP06160220
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
28 Virtual Ethernet/IEEE 802.3 interfaces
24 FastEthernet/IEEE 802.3 interfaces
58 Gigabit Ethernet/IEEE 802.3 interfaces
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
#sh module
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL06240XFY
2 24 24 port 100mb MTRJ ethernet WS-X6224-100FX-MT SAD03080079
4 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL062106CA
6 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX SAL09422XQ4
Mod MAC addresses Hw Fw Sw Status
1 0006.d65b.6e08 to 0006.d65b.6e09 3.7 7.1(1) 12.2(18)SXF4 Ok
2 00d0.bb09.1b60 to 00d0.bb09.1b77 1.2 4.2(0.24)VAI 8.5(0.46)RFW Ok
4 0009.1267.8e90 to 0009.1267.8e97 2.1 5.4(2) 8.5(0.46)RFW Ok
6 0015.f952.8390 to 0015.f952.83bf 1.1 8.4(1) 8.5(0.46)RFW Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAL06240Z8D 3.2 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL06230U51 2.3 Ok
Mod Online Diag Status
1 Pass
2 Pass
4 Pass
6 Pass
Edison Ortiz Sun, 09/16/2007 - 11:42
  • Hall of Fame,
    Founding Member
Open a TAC case and have the SP DRAM replaced.
Per your CEF output
This count should be zero. Good luck !
The closest match I could find was this.....
%MLSCEF-2-FIB_SSRAM_WRITE_INCONSISTENCY : FIB SSRAM Mismatch for Index: [dec]
Expected: [hex], Hardware: [hex]
Explanation A problem occurred when the system attempted to write the FIB SSRAM.
Recommended Action Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information that you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
emadehsan Sat, 09/15/2007 - 12:40
hi thank you for your reply
but as i said the sup wont get turn on.it remain dead! so i have no access to console
thank you
Edison Ortiz Sat, 09/15/2007 - 12:45
  • Hall of Fame,
    Founding Member
You never said that :)
If that's the case, you need to replace the Sup. Open a TAC case.
emadehsan Sat, 09/15/2007 - 20:45
i have two SUP2, but none of them works!
wehn i turn the power on , the status led flashe once, and then nothing else!
Edison Ortiz Sun, 09/16/2007 - 07:56
  • Hall of Fame,
    Founding Member
Are you the original poster of this thread ? If not, please open a new thread to avoid any confusion.
