3400 Connectivity problem
Sep 15th, 2007
Hallo Everybody
My first ME switch and I can not access it over ip
just because it needs a fancy config ?
The only access I can have is over console.
What ever I make it seems not to work
(simple vlan configuration:
Configure switch on a Vlan , then assign one port as switchport access for that vlan ,
and then try to connect to the 3400 but it fails. Not even ping operates. )
What is the problem with this device?
best regards,
paolo bevilacqua Sat, 09/15/2007 - 09:30
  • Hall of Fame,
    Founding Member
Config please ?
chris.iordan Mon, 09/17/2007 - 12:33
Thank you for your response
ME3400#sh running-config
Building configuration...
Current configuration : 912 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname ME3400
enable secret xxx
username x password 0 123
no aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 4
name new_vlan
vlan 10
name **connect_to_3400_vlan
interface GigabitEthernet0/1
switchport access vlan 10
media-type rj45
interface GigabitEthernet0/2
shutdown
interface GigabitEthernet0/3
port-type nni
interface GigabitEthernet0/4
port-type nni
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
ip address 10.10.10.10 255.255.255.0
no ip route-cache
no ip http server
control-plane
line con 0
line vty 0 4
login local
line vty 5 15
login
end
ME3400#
Vlan 10 is up/up , I connect in port gi0/1
rj45 pc with same network as vlan 10,
a) cannot ping
b) cannont telnet to the switch
sabbasaun Fri, 09/21/2007 - 14:42
I believe you'll need to change the port-type on the g0/1 interface to nni (default comes as uni):
conf t
int g0/1
port-type nni
end
